1 - 20 of 31 Posts
I am getting 56-58psi at idle but as i accelerate the fuel pressur will drop below 20psi and the truck canbarely go over 40-50mph. If i lift off the throttle the pressure will build again but once I press the pedal it drops again. The fuel pump started whinning pretty loud so I thought it was the fuel pump. I just put in the new FORD fuel pump assy and it still does it. What else can cause this pressure drop? The new pump whines also but not as loud as the one I replaced. Could I have a bad new fuel pump?
Are you sure you got all those parts in correct? Some people claim to have parts left over sometimes, because they couldnt figure it out, or the parts weren't originally in the fpr....?
Sent from my SCH-I500
What controls fuel pressure?
The fuel pressure regulator.
Fuel is in the tank. Gets sucked up in the pickup assembly. Suction line. HFCM. The pushed to second filter. Then either the injectors or the FPR. Then return.
New fuel filters?
The fuel pump produces about 100psi. The fuel pressure regulator reduces it to 65psi (+/- 5psi) with the "new" blue spring (it is slightly longer than the stock spring).
Potential causes for reduced fuel pressure (assuming a good fuel pump):
The pickup in the fuel tank may have debris restricting fuel delivery causing a reduction in fuel pressure (look at your primary fuel filter for evidence of the debris such as this silvery material indicating fuel tank delamination):
...or the bypass valve may have broken off (the small orange nipple in the black housing to the left of the pickup screen on the middle tube):
And check that the fuel pump is actually connected properly...but fuel pumps aren't always good - and many actually don't think highly of the Ford fuel pump to begin with...also is this actually a NEW and ORIGINAL Ford pump or a reconditioned or eBay part? Sometimes the "cheaper" part is in fact CHEAP-O.
I hope this is a simple fix for you. The troubleshooting guide from Lilpooh is excellent!
Jonathan
Discussion Starter · #7 ·
Thanks for all the help!!! When it started acting up I did pull the fuel filters and they looked good as they only had 5-6K miles on them. The diesel fuel looked and smelled normal. I then did the blue spring upgrade and cleaned the EGR valve. The truck ran better than new for the few test runs after. The next day same exact problem but this time it had the P0611 FICM code. Overnighted a new FICM from Ed @ FICMREPAIR and installed. That fixed the P0611 code but the truck still acted up and would barely go over 40-50mph. So I pulled the filters again and same result all looked good. I went and bought a fuel pressure guage and thats when I found out that the pressure was dropping when accelerating. The stock pump was louder than normal when the problem started so thats why I changed the Fuel pump with a genuine Ford HFCM part. The new pump is louder than my original pump when it was new but not as loud as the original pump became when the issues started. I am just baffled at what can cause this fuel drop when accelerating. I can rev the motor in park and its fine but driving it will drop below 20psi. When I stop accelerating it will build pressure back into the 50+psi range. If I baby the throttle I can keep it in the 40-50psi range. The only thing I did not do is drop the tank which is probably next on the list. If anything will do the harpoon mod while it is out.
When you start going, the injectors use the fuel. In idle, they barely use any still.
The pump is not able to keep up with demand for multiple reasons.
Weak FPR. You fixed.
Weak HFCM. You fixed.
Next would be the supply to the pump. Like you said, the tank.
After that, filters.
After that, possibly clogged fuel lines, which would be weird.
Discussion Starter · #9 ·
Ok I think I found the cause. I wont know until I get the tank back in but the rubber foot that holds the screen and the bypass plug both were just floating around the bottom of the tank. I did the harpoon mod while I had the tank out. Here is a pic of the 2 pieces I found in the tank.
Now just have to figure out how to secure the foot and bypass plug so they dont fall off again.
Administrator
That foot does just slip on the tube and you adjust to sit at the bottom of the tank so you can get all the fuel
as far as the bypass not sure how it is held in place ,,
but this wouldn't explain a fuel pressure issue but you may have sucked something up and created a blockage in the supply line??
Administrator
ps the foot should not be able to fall off the tube the bottom of the tank keeps that from happening once it's all installed but it should seal to the tube and not be a loose fit
That would create a fuel issue.
The pump couldn't suck up enough fuel, therefore if you don't have enough volume you can't create enough pressure.
Zmann it's right, they sit on the bottom of the tank, they can't fall off. Unless they were loose and were sucking air on low fuel level, then fell off when you pulled the tubes? Those little bypasses just snap in the side. I had to replace those on my 96 7.3, they broke apart in pieces. They look exactly the same. Not sure what the harpoon mod is, but you may be able to extend them down to the bottom with a piece of hose. They need to set on the bottom of the tank.
Suck, Squish, Bang, Blow!
The harpoon mod is when you cut the fill & overflow tube in the tank so you can get more fuel into the tank.
Discussion Starter · #15 ·
Thanks again for the responses. Well tried to reuse this part and it is starting to fall apart so I have to get a new one and Ford Parts is closed until Monday. So much for getting it back together and testing it. Does anyone know the part number to this so called foot or if they even sell it separate from the fuel sending unit it attaches to? I am going to blow the lines out in the meantime in case any trash got in the lines.
Administrator
only if the tank were say below 1/4 then it would pick up air when the fuel sloshed because otherwise it would feed fine from just the tube itself ,,
unless it were sucking the "foot" or the bypass valve that was floating around and that would cause a restriction
Administrator
oh and no good reason for that part to degrade unless BIO was used IMHO
that is the same Part that has been used for years ,,
I only know what mine looks like because I did a Titan tank and also Harpooned it
Discussion Starter · #19 ·
Thanks ZMAN, no bio fuel used. I know better than that. It isnt falling to pieces just fragile I guess is the word. I was going to use a zip tie to hold it on and it started to rip.
1 - 20 of 31 Posts
