1 - 7 of 7 Posts
My turbo just shot craps. I had just done the egr delete, oil cooler replacement, updated oil feed and drain lines and 6.4 banjo bolts. Everything was fine for a day and then started making noise. Pulled apart and has a lot of shaft play. What would have caused this to happen. Just want to make sure when I get a new one that it doesn't happen again. Could it not be getting oil for some reason?
Discussion Starter #2
Almost forgot I also rerouted my ccv.
Just crappy bearings in general or lack of oil. It doesnt take long to burn out a bearing, think how fast thats spinning around, lack of oil or quality oil will eat it up pretty fast also.
I had just put new 5w40 synthetic in it. Is there a way to tell if its getting oil? Could I have messed something up with the new oil cooler install?
nah, chalk it up to bad luck. who knows how the previous owner treated the truck. not letting the turbo cool down is a recipe for an early death
Ok. Is there a way to make sure it is getting oil? I don't want my new used turbo going bad right away. Pulling a big a** boat to the lake this weekend and really don't want to be messing with turbo issues once I bolt another one on. Thanks
Well I figured out what happened to my turbo. When I removed it I noticed some plastic debris had gotten in the hole where the oil feed line goes. I'm guessing this didn't allow enough oil to enter the turbo. Must have somehow gotten in there when I was re-assembling it.
1 - 7 of 7 Posts
