The plug that goes into the valve cover had a melt down on my 96 f350 withe 300,000 miles. Before I go and replace the valve cover gasket and plug what else do I need to check that might have caused this problem?
Thanks Dave
That’s a common problem, usually it just happens because of the design of the plug and gasket. I would make sure the glow plug relay is okay and not stuck on and maybe replace the glow plugs while I was in there.
Thanks Dave
My 95 did the same thing when I had it and it was one of the glow plugs on that side. It had really high resistance. I replaced the glow plugs, harnesses and the valve cover. No more problems.
KVFD
I agree i would change my glow plugs while i was there just because you are that deep you might as well. i dont know if they are the orginal glow plugs or not with 300k
