1 - 7 of 7 Posts
Hey guys,
About to order an innovative tune and am also ordering gauges. I havent decided on which ones yet. Im thinking EGT, trans temp, water temp, and fuel pressure. I think my stock boost will be fine (i think.. what are your thoughts)
but once i get all these gauges, what do you guys see on your rigs? I just wante to know what i will be seeing.
My truck is a 2006 f250 6.0 all stock except for a 4in exhaust.
Thanks,
Jon
Those gauges are perfect for a 6.0 :thumb: Or you could get an Edge Insight that monitors everything. lol
ive got a live wire. i see a steady 184 degree ECT at most ill see 30 PSI
Under normal driving conditions with the x-race from Innovative I don't see over 800*-850*. I've hit 1600* once for about 2-3 seconds but I was racing and did a boosted launch. I've never hit over 180* on the trans. temp. even pulling 16k-18k. The stock boost gauge will be just as accurate as an aftermarket gauge so you should be good, just don't trust the stock trans. temp. gauge.
Lt. Negativity
Boost - Crusing 5psi Max 35psi
EGT's - Crusing 800-900
Tranny - 165
Fuel Pressure - 63 all the time
HPOP - 1500psi at 75mph 2000rpm
Oil Pressure - 50psi Driving
Coolant Temp - 200, mine is tapped on the cooler I get temps of EOT n ECT mixture.
1 - 7 of 7 Posts
