1 - 7 of 7 Posts
There are 4 wires that are in a loom near the brake booster on the driver side that are just sticking out. Im wondering what these are for?
Thanks kinda what i suspected they were but where do they come out on the other side? are they loose or in a plug or something?
Thanks for the info
So do those go to each one of the Up-fitter switches. I always assumed that but never actually checked.
They are pass through wires that ford installed for user accessories to be able to pass through the firewall.
No. You will find the other ends just behind (upper left) fuse panel, drivers side.
If you have up-fitter switchs then yes they are hooked up to those.
They are not hooked up to upfitter switches but you can hook them up to the upfitter switches. They are dead ended right behind the fuse panel as stated earlier.
Dik
1 - 7 of 7 Posts
