1 - 20 of 23 Posts
Desert Shield/Storm Vet
Is diy Do it yourself? If so where Do I get the filter? also will it be as good as a s&b?
DIY is do it yourself
I get mine from Baldwin
You can go to Baldwinfilters.com and put in your zip for dealers in your area then call around for price on a PA2818. I get mine for $36-$38.
Lots of folks use other brands too. But I personally like Baldwin.
Yep its do it yourself. There is a link in that writeup with the part number to order the filter. I was thinking you were looking for a cheap filter as in price? It will filter as good and flow probobly a little less cfms for a fraction of the cost. Of course it won't look as good with the hood popped unless your after the bling:thumb:
I personally think that bigger is better is more bling, heck thats why we aren't talking about a geo metro.
You can't get much more bling than this;
Discussion Starter · #9 ·
By doing a diy filter can you hear the turbo more?
well i tell you what i have this exact same set up only i have an afe filter on it i will tell you this the filters are small and kinda flimz i am going to just buy the filter that alabamafrog was suggesting i would not spend your money on it because it doesent make the turbo that much louder it doesent sounds very good at all thats why im going with a bigger filter
and how do you like the sounds out of your intake filter alabamafrog??
Discussion Starter · #13 ·
Are you telling me not to buy the afe filter and to buy this filter PA2818
Discussion Starter · #14 ·
alabamafrog with the PA2818 can you hear the turbo more?
Discussion Starter · #15 ·
How often do you have to change the baldwin filter PA2818 or can you just clean it and reuse it?
you will hear the turbo alot more with an open element filter...
and the dry baldwin or napa filters are replaceable.
I just change mine every two years or so, depends on how dirty it looks. I drive 85% highway and 15% off road.
Discussion Starter · #18 ·
I ordered a s&b filter kit, a edge evolution new version with monitor and mbrp 4" turbo back exhaust kit. I will let you guys know how it turns out thanks for all the help.
You will be amazed by the power, that is until you pull up against a custom chipped stroke or a dodge.
Just picking, that will be way way better than stock.
Discussion Starter · #20 ·
I have a buddy thats got a 02 dodge with a edge box and a banks intake I need enough to bust his a$$ Now what?
1 - 20 of 23 Posts
