1 - 20 of 27 Posts
hey everyone. i tried this once and im going to try again for maybe better luck. I am looking for 16.5x12 Weld racing rims. either the stone crushers or super singles or if you have any weld rims that are at least 12 wide or if you got a 14 wide rim i would really love to see it. needs to be 8x170 bolt pattern. if you know anyone that has some and dont want to sell them. make them. :)
Discussion Starter · #2 ·
not even a reply :(
does anyone know a place you can even find those rims anymore? any help would be appreciated.
cj41foleyisathief
Call Weld. But you are better off going to 16, 17, 18, 19, 20.
cj41foleyisathief
Sorry I don't have a SD w/18's any more [00] EX has it [dam hot]
I have Dick Cepek DC-1 polished 18X12 8 on 170mm
I also have Mountain crushers 17X10 8 on 170mm
but dont see anything in our system that would be real heavy.
your right, I'm thinking 05 and up. I think the rotors are bigger, and you have to run a 16.5 on them.
Rebel
16 will fit i had 16's on my 04 F-250 CC.. I still have the wheels for sale also.. Have ot take pics if your interested. Thanks
OperationSmile.org
05 up have to have a minimum of 17 if I remember correctly. I have 16.5 on mine and I wish I would have gotten 17s. 16.5s are so hard to find tires for. Very few companies make tires for 16.5 inch wheels now.
ya, our 79 pulling truck has 16.5 steel wheels on it. We run the Truxus STS's on it. Great pulling tire. BFG TKO's also have a 16.5. There are actually a few differant brands we have run on that truck.
All Superdutys 99-08 that are singe rear wheel models use the 8x170mm bolt pattern.
Old body style(OBS) is 8x6.5
The 05-08's have larger brakes so the backspacing is different than the 99-04's.
In 05 ...engineers to upsized brake rotors by 5 percent, to 347 mm in front and 340 mm in rear.
Other improvements include larger calipers for both the F-250 and F-350. The front calipers have twin 60 mm pistons - up 11 percent from 2004 - for better braking feel. Rear calipers have twin 48 mm calipers on F-250 and twin 54 mm pistons on F-350 dual-rear-wheel models.
BACK SPACING
99-04......4"
05-07.......18"and 20"(from the factory) have 5.80" BS, and the 17" have 5.50"
00-04s came with 16s (unless it was a Harley Edition, they had 18s)...they don't clear the calipers on the 05-08s.
A 04 HD wheel would fit on a 05-08 since they were 18s, but they had less backspacing so they sit further out of the wheel wells on 05-08s.
05-08s fit on the 99-04, just rub on the leaf springs and sit further under the truck than they do on the 05-08.
Offset is the location of the wheel mounting surface in relation to the true center of the wheel......normally in mm.
Negative does move it inward.
So....
A 20x10 wheel with a 4.5" BackSpace will have approx -24 or -25mm offset.
A 20x12 wheel with a 4.5" BackSpace will have approx -51mm offset.
Rebel
BACK SPACING
99-04......4"
So....
The man has spoken.. Thanks Tank..:thumb:
Discussion Starter · #18 ·
thx for some help. but here is the deal. weld was bought out by american racing i think. weld still makes some of there rims like the cheyen 8's and the dune 6 and 8 and so on. i am looking for the stone crushers or super singles ( old ones not the super single II ) that they only made in 16.5x9.5 or 16.5x12. would really love the 12 wide becuase i gettin a set of 39.5x18 boggers to mount them on for my truck since i am buying a new one this is my toy. they pop up on ebay sometimes but if anyone find some. see's some or anything. please msg me and let me know. would really really appreciate it ;)
Discussion Starter · #19 ·
to the top.......... anyone for some weld rims? ill even try for 20x12 cheyenne 8's.............. anyone got those to sell?
1 - 20 of 27 Posts
