I have a 2003 F350 SRW, 7.3L PSD, Crew Cab, Auto, with 4x4 and adjustable pedals.
I have a problem with weak rear brakes, recurring. The rears aren't doing enough work. I bled the brakes back there and for the immediate time, they were better, however within about a week, the brakes were back to how they were.
I am wondering if anyone has seen this before.
I have 188K miles on the truck. The front calipers are new, the rears are not.
The rear calipers are original, but don't seem to be sticking. Wondering if air is possibly leaking in, although I don't know that this would make sense because the brake calipers are usually under a slight positive pressure from the head of the fluid from the master cylinder.
Is there something that could go wrong with the master cylinder that could cause this? The truck also seems to have trouble stopping on a dime when necessary, so I'm wondering if all of the brakes may be weak and if i need a master cylinder.
I have also heard something about some kind of failure inside the ABS unit on these trucks that causes a soft brake pedal.
Any ideas or suggestions are greatly appreciated. Thanks for your time.
