1 - 16 of 16 Posts
Is their a water seperator on my truck? Where is it located? How do i drain it? My truck is stock besides the mods i have listed below
im not totally sure but on the fuel filter housing there should be a yellow handle on the backside of the housing if you turn it (backwards towards the truck) it will leak fuel out and that is how you drain the water
is that the inline one?? cause i know my truck has the little nob but that doesent drain water???
Stupidity pisses me off
My 97 has the yellow valve on the side of the fuel filter housing, it is the water seperator valve. Any water in the fuel is trapped there and is removed when you drain it. (along with some fuel) when it gets empty it stops. Of course if you have water in the fuel tank etc. then removal of the tank and clean is probably the way to go
Shaking the Bush Boss
turn the yellow lever towards the back of the truck, and then back to the orginal position after a few seconds. Water is heavier than diesel, so it will settle to the bottom of the fuel bowl.
yea thats what i thought i always turn my key on for a few seconds and pump a little in there always seems to help prolly not the best with the expensive fuel lol
when should you do this???
I do it at least every oil change, some will say that is to often, or not often enough, but that is how I remember to do it.
How would it hurt??
it wouldnt i do it every oil change or if i know that i got a bad batch of fuel or something i people that never do it so i dont know
i just do it when the light comes on lol i have only seen it once. it cant hurt just loose a little fuel
Discussion Starter · #14 ·
my 95 does have that yellow lever on the side of the fuel bowl. if i do move towards the truck where will it drain too?
shold be a small drain hose hanging underneath/ or to the front of the engine(?). It will leak onto the ground or into your floor unless you use a drain pan.
1 - 16 of 16 Posts
