1 - 2 of 2 Posts
water pump went out on my 01 what do i need to do to pull the old off and put the new on what special tools do i need
Govy Magnet
The only 'special' tool you will need is a fan remover wrench...I believe its a 22MM...I have a Pneumatic one that makes life a whole lot easier, because it will be on there tight! Its regular thread I believe if I remember correctly. You will need a few buckets if you want to save the coolant you have in there, otherwise replace with CAT ELC. Besides that, its not all that hard, you can take the water pump off with the fan on but I doubt that would be fun. Also consider it a good time to replace the serp belt. :icon_ford:
~Phil
1 - 2 of 2 Posts
