1 - 2 of 2 Posts
So I just ordered a stage one cooling mist kit. My question is where should I mount my injector? I would prefer not to put it on the spider because if I go to sell the truck, I may take it off and don't want to spend a lot to replace it. Any ideas? Can I put a tee in somewhere? Thanks a lot!
Best place for it is in the spider. Its just a 1/8" NPT hole. You can always plug it later. You can weld a fitting in the cold side IC pipe as well, just requires welding a fitting in there.
1 - 2 of 2 Posts
