1 - 7 of 7 Posts
When is a good time to have a water meth injection put in? what mods should be done before this? it seems like it is a cheap way to get some xtra ponys
you can put it in a stock truck if you want.....
Water/meth is a good power adder, it will give you about 40hp at 40% meth. Dont go over that if you value your rods and motor.
Wait on water injection until you have done other things first.
2000 F350 Diesel Crew Cab, Long Bed, 4wd
Like what other things first? :dunno:
I would get a good turbo, maybe a set of injectors... Your bang for your buck is better.
Sorry to HIJACK
CSIPSD,
Do you need to run a custom tune for water meth? I bought a kit from a fellow org member and getting ready to play with installing it. I don't need the cooling at this point but my forged build is underway.:thumb: I will be attempting to mount a large P-pump off a 3208 or possibly a 9liter boat anchor:crazy:. Then I will need the cooling, I would like to get it figured out now.
Ole White
The meth is definately worth the money but as CSIPSD said it is much more noticeable with a bigger turbo and injectors. I could tell a diff before but even more so after my turbo and injector install
1 - 7 of 7 Posts
