1 - 5 of 5 Posts
Ok I just got a Water/Meth System from Cooling Mist
I have a question for the guys who run this kit
I have the 4 injectors
2 6 gal. an hr.
2 12 gal. an hr.
What combination do you run a 6 and a 12 or 2 12s
and a What mixtures do all you water/meth guys run
10meth/90 water
20meth 80 water
etc all the way to 50/50
What will work safely and get good power?
I am running 2 12 GPH injectors at 10 psi. I am running a 40-50% mix. I was climbing a fairly good grade the other day at a constant speed of about 65, when I turned on the Water Meth the truck picked right up to 70. I can definitely feel the little extra power plus it keeps my EGT's under control while screwing around.
I think for the hp range these engines are in you would use the 2 12 gph nozzles. For the track a 50/50 mix is good, and on the street I would probably just run water. But a 50% meth and 50% water mix is the max you can do an be reasonably safe. Experiment around with different % of water and meth for street use until you find something you like.
1 - 5 of 5 Posts
