Where do you guys mount your pumps at? I want to mount mine under the hood being that I am going to be using the windshield reservoir. Im looking forward to the water meth install!:icon_ford: Thanks!
Only place I could find to mount it cleanly is inside the left front wheel well. Behind the guard, on the cab near the driver door. I can get a shot of it when I get the truck back if you like. I spent a good hour trying to find a solid place for it, and that was the best I could come up with without moving anything else around. There is surprisingly little room under the hood for such things! I am having a custom tank built to fit behind the seat in my single cab. The small one that came with my kit needs to be filled all the time, and I don't even have the biggest jets in it!
Did mine under my intake, tucked to the fender panel
Mine is under the drivers door, on the frame... Might rethink the windshield washer res as a supply, unless your just looking to use it for power (which I do not recommend) as you will be filling it every 50-100 miles at most.
10 gallons would last me 400 miles or so when I was running lots of water.
So then what are your thoughts on a tank?
I have a 10 gallon tank mounted in my toolbox. However I have made several 4-8gallon tanks out of 6" PVC with caps glued on it and bolted to the frame under the truck. Then a small fill valve that comes up into the wheel well or even just under the truck that you fill with a hose.
