1 - 16 of 16 Posts
Ok i just finished my water/meth install and i was wonder about the mix you guys use? I also seen a post about the amount of meth in washer solvent already does any one have the details on the and what mix can i get the safest but most power out of it?
I usually run about 30% meth, but for the washer fluid depending on the freezing temp is how much meth it has it think. here is the ratio.
+20 - 7% methanol
0 - 23% methanol
-10 - 28% methanol
-20 - 35% methanol
-25 - 38% methanol
-50 - 62% methanol
I found 2 gallons of meth in my garage. My question is if i use it to mix do i use disstilled water, reg water out of a fausset to mix with???????
I buy the walmart brand -20 and mix it with three cans of heat per gallon of windshield fluid and that nets almost exactly 50/50 mix which is the max I know of that the manufactures of every major kit will recommend.
I have a 2 10 gallon reserves for mine. I fill them both up before a long trip when I am towing. You should see the funny looks you get at walmart when you are buying 10 gallons of windshield washer fluid and 30 cans of heat. I think I may have made the terrorist watch list on a couple occasions. :doh:
Discussion Starter · #10 ·
ok i ran my 40 meth 60 water and i got white smoke and felt like it was missing!!!! So i disconnected the ground so it wont turn on, The trucks ok but why did this happen?
The mix wasnt what i thought it was maybe?
It turnes by a boost switch at 10ish psi
It might be putting too much, mine puts 15% injection at 15 pounds of boost.
I'm not gonna lie. I have no idea how meth effects a diesel engine. I know that my 800ml nozzle sprays at nearly 78% when I hit max boost in the LGT. Every once in a while I'll conduct a test spray with the car being stationary and no matter how hot the engine is, my intake manifold will be cool if not nearly cold to the touch from the water/alcohol mix sprayig into it. That's badass.
I think it is injecting too early. It should be around 20 psi when there is alot of air flow. If I understand what you are saying once you hit 10 psi it comes on at 100% injection. I am assuming you dont have a progressive controller. It shouldnt be injecting too much because i am running two 625ml nozzles.
Discussion Starter · #16 ·
So today i turned the boost switch to 20psi and i dropped one injector to the 6 gal an hr from the 12.
All i have to say is:drool: HOLY ****!!!!!!!
Its honestly feels like my 95 lightning with the 75 shot on it. It pulls hard when it hits 20psi!!!!!!!! Im running a 40%meth mix
Thanks for the help guys!!!
1 - 16 of 16 Posts
