1 - 10 of 10 Posts
Okay, so its been a few weeks since ive had my down pipe, and now whenever i make a turn my water in fuel light comes on and then goes back off again, and its not just a random thing, every time i make a turn it goes on,
anyone know what causes this?
Discussion Starter · #2 ·
bump :bump:
yeah, no water there.
this only happens when i make a right turn. dosent happen when i turn left. ONLY right?
anyone have any ideas?
weird, bad ground somewhere? this is really a bump for ya.
i know, im sitting here like what in the hell could make it only light up when the truck is turning right?
:dunno:
Discussion Starter · #7 ·
bump :bump:
anyone got anything?
im leaving soon for a trip out to missouri and id like to know if this is a problem i should worry about?
Discussion Starter · #8 ·
:bump::bump::bump:
Id check your fuses? if they check out then i guess just go for it. you will have to refuel anyway so it would have burned it all off anyway. Just go for it bud
You've probably gotten the sensor wire rerouted somehow, or something was loosened and is moving against the wire or sensor plug in.. I'd start by checking the connections, tracing the wires and checking for anything that is loose.
1 - 10 of 10 Posts
