1 - 9 of 9 Posts
Hello everyone I was wondering what the chances are if my head is cracked or if its my block when I pour antifreez in my resivor it slowly drains out of my oil pan and when I turn the key on fuel pours out my drain plug as well any thoughts or suggestions would be appreciated thank you
Curious what led up to you testing the engine line this?
Well I seem a vidio showing a guy pour water in the resivor and it coming out the bottom of block so I tried that and after that I wanted to scan for codes so when I turned the key on I heard something draing out so that's how I found out diesel was coming out the disel was a accident
Has the engine been overheated? If not I would look at a very cracked injector cup(s)
So, you guys are saying a split cup -- may very well be, but then there is alot of this story that is not told
The radiator would have a lot of oil in it and the orings on the injector would have to be **** for both coolant and fuel to leak out the oil pan drain -- engine would have a contribution issue on the affected cylinder(s)
My injectors are only a year old same with o rings my radiator has oil in it if the cup was bad would turning the key let diesel pass thru it ? Also when I installed the injectors I lubricated the orings. What's your opinion hydro
Drain the coolant -- pull the injectors -- pressurize the cooling system with air(15 psi) and use kids bubble stuff(like from the Dollar store) to check for leaks at the cups -- if a cup is damaged you may see the evidence
Oring failure "could" split or swell a cup from pressure buildup if the oring between the high pressure oil and fuel, failed -- it is not uncommon for a 7.3 to "burn" oil thru the injectors by leaking from the high pressure to the fuel system -- I suppose if the mid and lower orings both had catastrophic failure, then enough pressure could be held by the upper oring to "blow" the injector cup
What are the chances? -- need to buy a lottery ticket
Fuel and oil could be pushed into the cooling system -- to get fuel and coolant out the drain plug, it would have to back up thru the oil system(could see coolant in the fuel bowl) -- or possibly the copper washer destroyed and taking the shortcut to the crankcase via the combustion chamber -- but should show evidence of hydro locking
I would think the engine would exhibit serious performance issues -- missing, sputtering, etc.
1 - 9 of 9 Posts
