What side of the red tube do you unplug for the wastegate mod? Do you remove it from the wastegate or the MAP? I know that I need to plug which ever side I remove. I would guess that it would be from the MAP that I would want to unplug.
Thank you
its on the right side I do believe
Unplug it from the head of the wastegate on the turbo.. Just pull the red tube then push the red tube onto one of the intercooler bolts.
Desert Shield/Storm Vet
Yep what Deputydog said:thumb:
