1 - 8 of 8 Posts
Does anyone have a picture on how to plug the wastegate? I don't want to screw up and have something happen if I do it wrong.
Thank you.
Unplug the red line from the wastegate and plug it on to one of your IC clamp bolts. Done deal.
whats the gain to this mod?
Slightly less turbo lag and maybe a couple psi more boost. It makes the wastegate stay closed longer basically. I plug the lil nipple on the wastegate for peace of mind. I used the squeezey end of a lil dropper and it fit nicely. OH and lemme just say, you have the best avatar on the org, hands down.
WW ZOODAD, FOIL DELETE, WASTEGATE
Thats the thread I posted where I wired the wastegate closed becuase I have the turbo out for the uppipes, but just unplugging the lines is alot easier, and I might still do it so the actuator isnt fighting against the wire.
The boost comes on def faster, and I hit the 28 in a hurry before the truck defuels. When you let off hard you can feel the motor kick a little bit from it, but that may also be my driving style with my 6spd. :doh:
I pulled my red line lastnight and i noticed the truck feeling peppier and also i was able to hit 75 (from 40 ish) before my EGTs hit 1250. before i would hit 1250 at about 55 to 60. my turbo seems to have a little more lag but not much. you should drive my wrx, wanna talk about turbo lag?!?! hahaha
Thanks turboseventhree. I like her myself. :icon_ford:
I traded from an 02 WRX to my OBS then to my 00 CCLB, yes there was lag, but it also revved to what 7500? and you cant drift a SuperDuty on an a cloverleaf offramp.
1 - 8 of 8 Posts
