It's all relays. You need a normally closed relay that opens when you press the throttle. Find the wire on the idle validation switch that has power when depressed. Tap into it and run a wire to one of the control tabs on the relay. Run a ground to the other control tab. Run the wire going to the EBPV actuator to one of the NC contacts, and another to switched positive 12V. Now when the pedal is not pressed the relay is closed and it sends power to the brake. When you press the pedal, it energizes the relay and opens the contacts going to the EBPV, and it opens back up. To lock up the TC, you have to ground one of the wires going to the tranny. I'm not sure witch one. I would just run a normally open relay with the control side feeding from the wire going to the EBPV, and the NO contacts will have a ground wire on one and the other will go to the wire you have to ground on the tranny. I know this sounds complicated, but its really pretty simple.
