1 - 5 of 5 Posts
Bring On The Snow
I am eager to install my leveling springs and new shocks tonight and I got the directions off the skyjacker website. My Question now is does anyone know the factory specs on how much to torque down the pitman arm and track bar. It does not say on the directions. Also people say that the steering wheel may become offset and will need to be adjusted. Your guys help would be great. Thanks in Advance
Bring On The Snow
Discussion Starter · #2 ·
:bump::bump::bump::bump::bump::bump::bump::bump::bump:
Bring On The Snow
Anyone????
The trac bar has a locking nut. Just get it tight. Be prepared though, this is a PITA to deal with. You may need to use a come-a-long to re-align the axle to reinstall the trac bar. As far as the pitman arm....I never took mine loose.
Your steering wheel will be off when you get done, I just took mine back to Ford and had them do a full alignment. I think it was $49.
Bring On The Snow
thank you very much. I guess i will see how it goes tonight.
1 - 5 of 5 Posts
