1 - 12 of 12 Posts
?Any descent stuff at walmart? I been running diesel klean in fuel from there.
Don't you worry about it
2017 F250
Thats as good as any
If you run a good engine oil you do not need an additive !
I run Mobil 1.
2017 F250
I misread that. You shouldn't need to run any oil additive.
Do you have injector stiction?
If so nothin at walmart will help.
Look into Rev X oil additive
Ill probably run hot shot next oil change can pick it up tractor supply. Cant find revx local
WWW.COMPIGNTECH.COM
I use diesel kleen white all year long in my f-350 and my fathers fleet trucks.
I tried my own little experiment with that stuff. I added it to my fuel every fill up on my way to Florida last summer for vacation for the first 500 miles and then did it without for another 500 miles and the same on the return trip. I saw no gains in fuel economy like they claim on the bottles.
Hot shots doesnt work. Dont waste your money
War is the answer!
If you want the best fuel additive look up XPD. Rev x is good but pricy. I would use arcoil instead for the oil.
Sent from my SPH-L710 using AutoGuide.Com Free App
1 - 12 of 12 Posts
