Fellas I need some help. Have an 02 7.3 about 3 days ago noticed my voltage light or the “battery light” as most people call it pop up on my gauge cluster when I started my truck to warm it up. Stayed on until I got in it and took off. As soon as I started driving it it went off. Did the same thing the next day so I tested alternated with it running and seen the alternator was only sending out about 12.8v so I replaced it. Put the new on and it’s still only sending out about 13v. Batteries are right around 12.4v with truck off and 12.8ish with truck running. Just to make sure I didn’t get a bad alternator pulled off another one off my other truck that is good put it on and same thing. Tested to make sure voltage was going from alternator to batteries. (One multimeter lead on ground of battery other on the post of the alternator) tested the plug for the alternator and have 12.8v with the key in the on position. All seems well between battery and alternator and the plug that plugs into alternator. Had a guy tell me to check I believe the number 29 fuse under the dash which is a 10 amp and it is good as well… so I am stumped. What am I missing here. Where am I losing voltage? Or why is a brand new alternator only producing about 13v? I thought maybe I have a bad ground somewhere? I’m assuming if I do it has to be a ground that goes from block to frame but I can’t seem to find one to check? Or am I not seeing a fuse somewhere that needs checked? Any help whatsoever would be highly appreciated. Thanks in advance
