hey everyone
iam getting this wierd vibration feeling between 80 and 90KM and 1500 to 2000rpm. like it vibrates hard.i can feel it in the seat as well as the steering wheel. i just had my tire balanced and that wasn't it. is it my steering some where down the line. drive train,axle,brakes or the worst the tranny some how. any help would be great thanks much
a-rod
:bump: :bump: :bump:
arodrigues, i just went through a similar issue. I hope you dont have the same problem. I installed a brand new ATS transmission in my truck , and had the same issue you discussed. Over time, the problem worsened and finally, I had the transmission pulled from the truck. The problem was that the transmission case itself was cracked. The vibrations initially started at high rpms, but as the crack worsened, the vibrations occured at lower and lower RPMs.
Hope this is not your problem.
