when placed before the pump, it works.
after the pump, no go.
trying to go from appleseed to gl 1 day.
3/4 brass t filled with solder. 1/2 hole with 1/8 vent for vac.
hf pump
bigger pump? dif sizes on venturi?
thanks in advance
R.
if its before the pump it is just vacuming it into the mix, if its after the pump, your container that you are drawing from needs to be at the same level as your venturi. I just have my methoxide drawing in before the pump, and it seems to work fine, plus running it before the pump, it agitates it, for a better mix anyways.
You have a venturi like graham laming shows on his site?
the soldered one yes. not the hammered copper.
i can leave my carboy on the floor and it will pull it up. if i place it after the pump, no go.
I have my carboy plumbed pre-pump and it sits on the floor and works just fine. If you can control the rate that it feeds the methoxide in say 10 mins to feed it all in, then you are good to go. As I said above pre-pump lets the impeller of the pump give its first good agitation.
i must have done something wrong then. back to the drawing board.
