well i think my vacuum pump went out, i have no power brakes, i took off the line going into my booster and felt for vacuum and there is just a tiny bit at idle. does that mean my vacuum pump is bad? it was ok when i pushed the brakes and if i did it again real fast there would be no power brakes, now no power brakes. pump or brake booster....also any one know the part number?
try autozone.com. just replaced mine last night. pedal would be good first time then get hard as a rock.
they are about $100 from an auto parts store. could also be your brake booster. does your AC switch between vents? anyone else know what run on vac that he could test?
