1 - 5 of 5 Posts
I did a bunch of searching, and found some good info. But, I couldn't get a hit on one of my questions, so thought I'd ask it. My issue seems to indicate a vacuum leak or a vacuum pump issue. I live in Idaho, so haven't used the AC in a while, and only used it today because we made a road trip to CA to visit family. It was 80 on December 28th.
A few months ago, I noticed that I couldn't hear the vacuum pump activate for a few seconds after I turned my key on (didn't realize at the time it was the vacuum pump, just learned that searching for this issue). Would that tend to indicate a vacuum pump issue, or would it possibly not turn on if there was a leak? Or, would a leak tend to make it stay on longer when turning on the key?
I will check for leaks obviously, but didn't realize at the time that the pump was not making noise at the KOEO position. If so, then I will need to buy one.
I also have manual hubs.
Thanks for any info!
Since you don't hear it turn on its probably a bad pump. You should also check for leaks to be sure. My auto hubs were leaking so disconnected all of that and plugged it off. The hubs are now manual but I don't use all that much any way so no loss for me.
Thank you, I plan to check for leaks today. I may play around with the pump too to make sure that something didn't get disconnected, but sounds like I'll probably needing one.
the system should be able to hold vacuum even when shut off. To make sure the pump is the issue, pull the line off the vacuum canister. the pump should turn on in a few seconds max. The canister is on the passenger side fender well under the hood. Easy to get to. Also you can pull the electrical plug off and re-insert it to see if it came loose.
If both of those fail, you may check a fuse. Not sure if this is the only thing on the circuit but worth checking as the vacuum pump is expensive.
I do not recommend a Dorman pump, buy one from Ford or get one from a pick and pull. My Dorman took a dump after 6 months and 6K miles.
Good luck
-K
Good luck
-K
I didn't see this until after I replaced the vacuum pump, but thanks also for your reply. I did try disconnecting and re-seating the electrical connector, but that didn't help.
I figured since I didn't get any noise from the vacuum pump, it was probably bad. So, I picked up a new (not rebuilt) one from Napa with a lifetime warranty for $91, got it in (easy job!), and all is good.
Hopefully this helps someone else in the future when searching.
1 - 5 of 5 Posts
