Replace the vacuum pump.My vacuum pump failed.
What would you do?
I'm willing to bet because you can easily rebuild the journal bearing turbo. Ball bearing turbo not so easy.Engine S/N starts with a 0 so I have the old HPOP.
@[email protected] Any particular reason for recommending the KC300X journal bearing over the TP38r ball bearing turbo.
That is exactly why, and their newer journal bearing chargers perform nearly as well.I'm willing to bet because you can easily rebuild the journal bearing turbo. Ball bearing turbo not so easy.
