1 - 2 of 2 Posts
I want to install an Aux. Fuel tank pump and I'm not sure about the wiring. I located the wires behind the fuse block but I think the wire is too thin. Do I need to directly hook up the 12 gauge wire (from Pump) to the 18 gauge (orange/green)? What about the relays? :dunno:
Thanks,Marty
I have the same setup, for my tank. I used a key on power relay to supply power before the switch for my transfer valve solenoid. I use to have it wired direct from battery supply and forgot it on. It killed both batteries. left me straded.
1 - 2 of 2 Posts
