1 - 9 of 9 Posts
Having a hard time unbolting the exhaust downpipe from the turbo. Anyone have any tips on what size socket is needed for the bolt on the back of the downpipe connector since the bolt is on the back of the engine bay?
Thanks in advance!
Discussion Starter #2
bumpskey...
Psh. Mine is welded on. :thud:
In the middle of installing my stacks, and Im at a stop because of this problem.
i had the same problem when i put my exhaust on. i went and bought some PB Blaster and sprayed it on and let it sit for the night. the next morning i tried it and it came off very easy. but be careful because it is hard to find the O-ring if you break or bend it. hit me up if you have any other problems
John Wood Nut Swinger
The down pipe is held on by a V band clamp. I believe it is a 3/8" socket, you will need a deep wall.
ok im gonna try a 3/8
PB Blaster is the shiz! Love the stuff.
good luck smitty! You best be postin some vids when you get those hooked up!!!!!
1 - 9 of 9 Posts
