1 - 20 of 43 Posts
So, my truck has 11,900 miles.
Its been in the shop at 4,000 for an oil leak.
4500 for another oil leak, and power steering pump
6,000 for blue smoke
10,000 for a radiator that ford swears isnt leaking.
and now at 11,900 i have this... and btw, the oil has 4K miles on it
And here is my radiator that doesnt leak
It's a diesel . the oil is going to look like that.
man that sucks, I hate to hear about that, Its a shame you spend so much on a new truck, having problems are bad enough but then when the dealer/ford wants to give ya the run around it makes it that much worse
BIG TRUCK, SMALL DRIVER
Try a different dealer, if possible.
I agree that sucks having that much problems with a new truck ... and if the dealer keeps giving you the run around , go to another one ...
Discussion Starter · #7 ·
I have been hearing about the 6.4 having issues with fuel in the oil and the dip stick showing over full, in one case it was the high pressure fuel lines under the valve covers leaking if i remember correctly.
Discussion Starter · #9 ·
you sir, are correct
is it supposed to be 2 qts over full? i know what a diesel's oil should look like. this is my third one....
Sorry I didn't notice it was overfull
Discussion Starter · #11 ·
i forgot to add, the truck about 80 man hours of paint work to correct deficiency from the factory
Brand new engines are bound to have problems man. The 6.0's had alot of problems didn't they. Get a 7.3 :icon_ford:
I am at 92,000 miles on mine and it will not even climb the slope to get into the garage, a $61,000 po$ 1000% ,rad has also been leaking ,but never at the dealer as well -- huuummm but loses 2 gallon a week and I have the same green stain on the lower support as you do. I have given up on Ford and plan to just put an engine in the truck that has proven to me that it runs for many miles - I bought a wrecked 02 2500 Dodge with a 24V and a 6 Speed last week and it will be a rattling ,smoking and running 08 Ford when done.
Yo: Turboseventhree: You will have to buy a truck sooner or later. Maybe you should learn some manners. Been driving Ford trucks for 40 years now and have had alot more probs. then this. You have to remember they were only covered for 12,000 miles up until a few years ago.
737tdi
My truck has 70K on it and I feel I don't have enough oil leaks to keep the engine area from rusting. Its my 2nd diesel that is like that. Most trucks or cars I ever owned have been wet enough to keep it from rusting. So I have to spray oil everywhere required.
Discussion Starter · #16 ·
when they make a 7.3L with common rail, a good auto behind it, and that doesnt ride like tank, i will. my wife daily drives my truck, so it needs to do more than run good
Hmm, the only thing I have been in that rides better than my 02 is a new duramax. However, the interior was flakey compared to my truck that is 5 years older. Yeah the auto won't hold alot of horsepower, but it sure handles what the truck came with. But then, I buy a truck to use as a truck.
Then go ahead and buy the Chevy. I would have but it is butt stinking ugly. Walk outside and see that sitting in the drive would make me hurl. Just couldn't do it.
737tdi
Discussion Starter · #19 ·
then you havent ridden in an 08 ford, and if you did, something was wrong. the ride between the 08's and leaf sprung rigs are night and day. And i use mine as a truck, but i use it as a family hauler too.
that is the neat thing about technology, things get BETTER!
737tdi
no plans to buy a chevy, but if i lemon law this, a v10 is looking good
I dont like all the emissions BS on the new ones....Isnt it envirnmentally safe EITHER way? all that comes out is particles correct? no polutant chemicals?
But im sure ford will get all the kinks worked out. It happened with the 6.0, and they got it workin perfectly.
Sorry for your bad experience. Hope it all gets worked out. I can understand your frustration with the stealership, once they sell it to you, they wanna sc3w ya! cant say i like dealing with them either!
1 - 20 of 43 Posts
