So yesterday morning when I started my truck it started just fine, then when I went to back out it went a couple feet and died and wouldn't restart. It turns over just fine, but won't fire.
Here's what I know so far:
2001 F250 with 7.3 Powerstroke
I changed the Cam sensor to no effect
I've checked every fuse in the truck and found none blown
When I turn the truck over the starter gets it up to 170 RPM
Changed the fuel filter to no effect
When I drain the fuel bowl it fills right back up with the key on
Unplugged the oil pressure sensor and tried to start the truck to no effect
When I turn the truck over for an extended amount of time the "Low Fuel" light flashes
I have not check the batteries, but the voltage on them reads around 10.1 at this point (it was over 12 when the issue started)
That's all I can think of so far. I'm guessing my problem is electrical, but I'm having trouble pinning it down. Anybody have any suggestions for other things to check?
Thanks,
Jake
Thanks,
Jake
