i just installed this on my turbo, and set it to 2" like the directions said. They also said that adjust further from there. I was wondering how i would determine whether or not i needed to adjust it?
Did you ever adjust it:dunno:?i just installed this on my turbo, and set it to 2" like the directions said. They also said that adjust further from there. I was wondering how i would determine whether or not i needed to adjust it?
I think you have boost leaks somewhere. Check you CAC tubes for leaks and tighten them down if need be. Check your up-pipes for soot around the collectors, that's a sign of leaky up-pipes which could be the cause of your low boost numbers.I am wondering if I need to check for leaks in the boost system? I will tighten it down another .25 and see what the change is?
