2002F3507.3
my turbo isnt turboing,
ebpv is open, turbo spins free no binding, wastegate appears to bein the closed position
only produces 8psi wide open, plumbing looks good, boots good tubes good, does IC get leaks and how do you test? IC looks ok.
can turbo exhaust impeller go bad? Whats wrong?
thanks for the help
Maybe a leak in the plumbing to, and from, the IC?
Sometimes the hardpipe rubs next to the PS pump and gets a hole in it, maybe a boot's off somewhere?
On my 99 I once had a slight crack on the drivers side piping right at the seam. I could not see it unless it was under pressure. Just a thought.
