What do you mean by smaller exhaust housing?
Youll need a 3/4 in. freeze plug for the outlet housing. You need a bolt and a tap for where the rod went through i dont remenber off hand what size. On the housing the rod sits in there is a snap ring that comes out that holds the ebpv rod and spring. Pull that out and put the cap back on with the snap ring and your doneWhat all do i need exactly to do the delete. Like what i have to buy, what size freeze plug? I read I need some locking clip or something so the plug doesn't come out.
