i just got a boost guage for my truck and it says connect the barbed fitting to the guage with the hose on it ... simple enough and on the other end it says put a t connecter in the vacume line it has me confused im not sure where or if the truck has a vacume line every boost guage iv seen has been drilled and tapped into place any help would be apprecieated im not sure where to find the vacume line
you can "T" off the map sensor thats on the passenger side theres 2 wires and a rubber hose going to it, or you can get rid of your AIH (air intake heater) and use that instead of drilling and tapping, I choose the AIH delete. you will need an adapter to fit the hmmm sorry forgot the size of the AIH to fit your fitting and your good to go.
ok thanks ill try running it off the map as i live in canada id like to keep the aih on the truck thanks for the help :D
I bet you hardly use that AIH . . .
Maybe you got a vacuum gauge? Anyway, you can either drill and tap the spider or just tee into the MAP sensor line like stated.
