1 - 17 of 17 Posts
Looking to get a better more reliable turbo setup that i can still run on stock fuel, still compounded, and not elite. Looked at I.I phatshaft setup, but would like to see what you guys think.
What's wrong with Elite's setups? I run their 71mm Tow Power atmosphere and couldn't be happier. There are a lot of modified stock turbo kits out there though. Industrial's is good but they use a K31 billet wheel for the atmosphere which doesn't move the air that the 6 blade Precision wheel Elite uses in their setup. River City Diesel and Swamps Diesel Performance also have modified stock setups.
Hey Jeff i don't want to bad mouth anyone, but I live in Pueblo, Co where Elite started and they practiced some unethical business tactics and rubbed some of my close friends the wrong way so i prefer not to give them my business. After looking at some other threads i think the batmowheels is the best option that will fit my budget.
Are you going to go with both batmowheels or just the LP batmowheel?
with just batmowheels, a wastegate probably wont be needed. If you still have your EGR in place then you really dont need one.
What he said. That is the main reason i am going with a batmowheel. I would do studs tho if you dont have them already.
Honestly, I wouldn't go the Batmowheel route. They just haven't been proven. I wouldn't spend $800 on something that hasn't been proven.
I believe Swamp's has a billet compound turbo setup similar to Elite's Tow Powers, but with a much cheaper price. Around $1,750, IIRC. :thumb:
Swamp's will be building my turbos when the need arises.
The LP batmo has been proven. Rudys tested it and got more hp and lower egt's. Also people have reported that it cleans up the smoke on a big tune nicely. The HP batmo i dont believe has been proven. I dont think the LP batmo is a bad deal for $400. :thumb:
I think the Swamp's route is the best route to go if you're on a budget. If you do decide to go with the batmowheel upgrade, I wouldn't invest in the high pressure wheel. The low pressure wheel is going to be where your gains are.....and they will be minimal.
Jeff,
Ok time for the question of the minute, What is the formula for turbos and stock fuel.
Trying to get a handle on the different turbo set ups for towing.
Tow powers,
Max Torque power
Phat Shaft
etc.
A smiple engineering explaination would be great.
Talk to Elite and did not get any kind of explaination that made sense.
Nearest thing I can figure is:
Small wheel on the high pressure side will spool faster but run the risk of overspeed.
Larger wheel on the low pressure side max out at 71 mm will flow a bunch of air but again might overspeed the hi pres unit. going bigger requires more fuel ( Bigger pumps and injectors)
Going too much bigger than 58mm on the hi side requires more fuel to "lite the turbo" hence bigger pumps and injectors.
I am not building a 2000hp drag truck just want to to be able to make the engine most efficent in the lower RPMs. (1500-2500) I have some great guidance on a direction to go right now, just tring to understand where "the line in the sand is" and why.:dunno:
Now add to this better flowing manifolds and up pipes which is simple math mean lower pressures at lower RPMs but better flow rates. things get a little confusing.
The plan as laided out is New improved Intake manifold, steel steed Exchaust minfold and up pipes, and a new turbo package all of this will include new head studs and since it is not a race truck nor will it be operated as such so, no wastegate or blow off valve.
At 10,000# I am not racing anyone but the fuel station. add to this an additional 10K in Camper and trailer racing is just not in the cards.
I would stay away from steed speed for the moment until they figure out why they lost power on a test truck.
More info please
Check out the threads on powerstroke army. I think on Mike's truck they lost about 70 hp with the only difference being the steed speeds. They are working on a new design currently and trying to figure out what happened.
When I upgrade my turbos, I will get Swamp's to build me a set based off of Elite's High Powers. I hear it is a super fun and clean setup to run with stock fuel.
Bump Jeff any insight?
1 - 17 of 17 Posts
