question about turbo pedestal. 1999 7.3 early turbo.
turbo pedestal has oil pressure and oil return. I guess small hole is pressure side and large hole is return side. I can blow air (by mouth not high pressure)
into small hole and air comes out small end. When i blow through large hole
air comes out large hole , but also comes out around wastegate rod. Is this normal ??? If yes -- seems like oil would run out around rod.
