drivin down the road and all the sudden there is a cloud of white smoke what do I do.
duct tape & zip ties
What was your boost level. What was your egt's when this happened. Need some more info first.
i dunno was goin about 45 mph just cruzin thru town
How was it running when you got the white smoke. Did it start running rough, did you loose your boost.
White smoke usually means starving for fuel or burning antifreeze. You need to do some diagnostics on this.
Scan for codes, check under the hood. Look at the intercooler tubes see if any of your boots are off or loose. As this will cause no boost or low boost readings.
fine no other problems just oil and smoke out the exhaust
Pull intake tube off turbo and see if there is a lot of oil and any play in shaft??????
