1 - 12 of 12 Posts
just wanted to know if this waste gate control is worth the money it all sounds good in theory does anybody have one would this work better than just unplugging the red boost line
its a very simple design and makes since does anybody have one
I have one and it works very well. With just a couple of runs you can set it to dump boost at any psi you want. It operates smoth and percise and its a great inprovement of the stocker. Other than beening a little tough to install with the turbo on the truck due to the very small c clips u have to install. Hope this helps.
so its performs better than just an unplugged waste gate
the main reason I got one was to make it alot easier to adjust the wastegate. I think it does a lot better then the stock wastegate controller. But remember anything more than about 25-27 psi of boost will eventually kill the stock turbo.
Discussion Starter · #10 ·
so bottom line is it worth the money
1 - 12 of 12 Posts
