I just installed my third rebuilt turbo and it is leaking oil out of the turbo bushings. There has to be another problem. I do not seem to have excessive low pressure, but the truck will not stay running. It runs for a while then will miss once then idle fine then miss. When driven you can go a mile or two then the truck will die then if I wait a couple minutes it will run again. I just put in a new IPR, ICP, Low pressure oil pump, and high pressure pump. When it dies if you try to start it right away the injector pressure will not go above 200 psi until you wait a minute or two then it goes up to 1100 or more and starts up.
Thanks for any advice
