1 - 5 of 5 Posts
Hello, just noticed when I put a little pressure on the accelator to pick up speed, or pass someone that my turbo seems to be ticking pretty loud a little like the old valve lifter pecking noise when gas engines are low on oil. Don't start until around 10psi or above and quits as soon as boost goes below 10. Any ideas? Hopefully not a failing turbo.
What was the issue? I’m having the same problem
Turned out what I thought to be a ticking from the turbo was actually a busted pipe from the exhaust manifold to the turbo as well as leaking bellows on the passenger up pipe. Cab removal and turbo up pipes replaced and all is well again.
1 - 5 of 5 Posts
