1 - 13 of 13 Posts
How the ()*#$%)(*&$% do you get the oil return line on the bottom of the turbo seated?!?!? If I get the turbo in the right place it's because the oil line isn't in, when I get the oil line lined up I can't move the turbo....
Help!!
Not so fast.
Got everything buttoned back up, and having two issues.
Isuue #1: Feels like it's running through molasses, very little acceleration, like constant turbo lag. Would I need a reflash for switching to an 03 turbo? Or disco the batteries?
Issue #2: Got a steady drip from around that ill-fated returnl line. Let me guess, I get to take the whole thing apart and do it again?
Not so fast.
1: don't know. PM scuffy828
2: That is your prize!
Discussion Starter · #7 ·
Shouldn't have to. I don't know of any one that has.
As for the molasses, thats weird. Mine spooled faster then the old one.
I hear it sooner than the old one. I just don't have any boost, or at least thats how it feels.
Discussion Starter · #9 ·
Anything on the boost gauge?
Gauges aren't installed yet.
I haven't tried using the live monitor feature with my X3 yet though, not running a tune so didn't think to try that...
<--Pro Cooler Racer
You'll want to find out if you are getting any boost, and if you are, how much, and how fast.
Discussion Starter · #12 ·
Just want to triple check here before I send the turbo back to the Ebay seller,
An 04 with an 03 turbo installed will not require a reflash, correct??
<--Pro Cooler Racer
Correct. I did an 07 to an 03 and did not require a reflash.
It shouldn't have any lag and I gained (and others too) a couple lbs boost running the same files.
1 - 13 of 13 Posts
