1 - 5 of 5 Posts
Question, 06 F250. When after engine heats up I notice my boost pressure goes up to 20 or 25 and when accelerating again the boost maxs out and throws a code. Any ideas of cause or is turbo going bad??
Questions...
  • What code - precisely - is being generated?
  • Does this truck have a catalytic converter?
  • What is the map pressure KOEO?
  • When your truck is hot and the boost is high, does it make a difference to the MAP reading if you take a stick and push on, hit, and/or otherwise mistreat the goofy wire holder protruding from the rear edge of the engine compartment immediately above the turbo?
Reactions: Patriot
I'll have to check on all that and check back. Thanks for answering. It is 6.0 diesel.
1 - 5 of 5 Posts
