1 - 11 of 11 Posts
· Registered
Honest truth I raced a Tundra and beat him by a truck length, but I held the egts to long about 40 seconds hitting 1600. I take off my pyro shoots up, boost is fine but the egts get hot. I try and hit 55 MPH to 60 and I'm in the 12 to 1300's if I try and get to 60 MPH. Did I screw myself and fry my turbo ? It starts fine sounds good when I shut it off no clang clang just hear the spin nothing bad sounding. I looked at the boots no holes no hiss sound. Just the egts shoot up fast when I take off from a dead stop on a normal take off nothing fancy .
· Premium Member
Is this different from how the EGT's would react prior to the race?
· Registered
Yes , big difference.
· Premium Member
I would think you have a boost leak based on the symptoms you describe. How much boost are you building under WOT?
· Registered
I hit 40 mph I'm in the 14 to 16 Pyro. Boost is good nothing wrong there and no smoke or noises or cracks in the boots.
· Premium Member
So boost appears to be the same as before? Can you datalog boost and exhaust back pressure at WOT?
· Registered
Discussion Starter · #8 ·
Pyro gauge was the problem it went out and was reading wrong . Thanks for all the help guys!
· Registered
Discussion Starter · #9 ·
New Gauge all is good ...
· Premium Member
Good to hear, Mike! Was the old one made by AutoMeter and did you replace the new one with AM?
· Registered
Discussion Starter · #11 ·
Yes it was AutoMeter 0 to 1600 pyro and was replaced with the same thing .
1 - 11 of 11 Posts
