1 - 20 of 51 Posts
Sounds like my turbo is fluttering a little while after i switch to 5th gear and have it hammered whats the easyist and quickest way to stop fluttering.
sorry if this is in the wrong forum wasnt sure where to put it.:dunno:
PMR = JUNK
Get a wicked wheel. That will fix it most of the time and is the cheapest way to fix it.
Wicked wheel about $100
Ported housing about $400??
Beat me to it:doh:
I have a early 99 so it has the wicked wheel from the factory, on my tow tunes (heavy tow or agressive tow) pulling a decent grade in top gear I get loads of flutter to the point I always have to let off and keep the boost around 18-20 max
So I dont know if the wicked wheel is goin to be a cure all for you
PMR = JUNK
Right, the WW will not always cure it. It cured mine, but that doesn't mean that it will cure yours.
The wicked wheel will help but I think the housing should clear it up.
Alright thanks guys ill try the wicked wheel for now cause im to broke to afford the housing i can barely afford to keep diesel in it and it goin down the road
Powerstroke Junkie
What you have is called "Turbo Surge" do a search and you will find a lot of info. Some promise the WW as a cure, but it doesn't always work, the only for sure cure is the new housing. Or different turbo, really big $$$$ I suggest keeping your foot out of the go pedal.
NCH
Let's go B's!!!!
The "easiest and quickest" way to stop is to get off the throttle when it starts surging. I know $$ is tight, so thatmay be your best bet. If you want to spend money to "fix" it, then follow these other guys adivse :thumb: My ATS housing fixed mine. :D
Discussion Starter #11
so does surging hurt my motor or turbo?
Discussion Starter #13
o.... well how long do i have till it is destroyed?
Other vehicle is an F250
PMR = JUNK
WW fixed mine. I didnt wanna afford the housing either
Discussion Starter #18
Alright i got a guy from DSP here in waller and hes getin one shipped in for me it will hopefully be here by the end of the week WW that is
You'll need an impact wrench to get the old compressor wheel off.
1 - 20 of 51 Posts
