1 - 8 of 8 Posts
1995 f350 while driving around 50 - 60 mph l am showing 0 boost but if l get into it it shows 10-15 pounds . Not sure is 0 boost at normal speed is what it's suppose to be.
i remember when i had an edge monotor i think i only ever got around 2 lbs of boost just getting up to speed, mostly showed zero cruising until you started going wide open
I get about 1 or 2 at 70 mph. Anything under that I have none unless going up small amount in elevation.
you've probably got an issue then.
70mph maintaining speed on level ground should be around 5psi, accelerating from there should quickly climb to 15psi or so
normal acceleration from a stop should slowly build to 5psi or so, floored acceleration from a stop should climb to 15psi and stay there.
1 - 8 of 8 Posts
