1 - 5 of 5 Posts
Hey everyone, new to the forum and looking for some advice.
I’m building a 6.0 PSD for my daily and I’m stuck on a few items, mainly injector and turbo size.
here’s what I’ve got so far:
.40 over ceramic coated pistons with .30 milled off (thanks to the machine shop damaging my block) with .50 pockets for valves.
Ordering 6.4l lifters soon for extra clearance
Stage 2 Callies Cam - 180/200 dur @ .50 378/378 lift
stock valves at the moment.
looking to buy WDI 175cc/30%injectors
Warren Diesel suggested the injector size. Is this what I should run?
What turbo will match nicely with it? I will run the stock VGT turbo for a little while until I can spend the money on a new turbo.
Anything else I need to look out for or change out? (Valves, valve springs, lifters, HPOP, etc)
I’m aiming for 550-600hp with tune. Currently running a SCT tuner but open to other ideas on tuners as well.
thanks for any and all advice and pointers
Discussion Starter #2
I should add that I have a 4” MBRP blow through exhaust (no muffler and hollowed out catalytic converter) - it’s how I got the truck.
190/30's and a KC stage 2 turbo. You'll like it
You won't be hurting those components at that power level. You're more likely to have head problems. Are you studded? Have o-ringed heads? Those things are going to be your issue before blowing out the bottom end.
1 - 5 of 5 Posts
