1 - 20 of 70 Posts
I don't know what happened but every setting on my chip is running way too hot and shifting like $hit and smoking all kinds. i took it out and my truck is fine...just slow lol. it is a TS chip with a TW reburn. any ideas?
Has it always done this or just started?
Could be a bad connection on the switch or the chip its self.
Pull it and reinstall it and see what happens.
You need to get youre truck on a scanner and do some test.
Did you bump or pull the wire at all did you get any water in the PCM. Pull the PCM and check it fo any water damage some trucks will leak. Is there notacible diferance switching from tune to tune.
A chip will make a problem with the truck more noticable than it will be in stock form. There realy isnr much to go wrong on a chip unless it gets shorted out or pulled while the key is on.
W
Guest
talk to tony after you try what was said above... might need to put a pressure gauge on the trans to see what the line pressures are... the truck may have a shift kit or different VB in it...
Is there any difference in the settings when you switch the positions or do they all feel/act the same?
I don't see how this would find out the problem or not.
My chip feels the same in every setting up till 1/2 throttle then there is more fuel. When you just switch through them you can tell at all.
But my question is do you have a high idle or something to try and see if the chip is really switching positions?
Since you dont have a TW you probably dont know. But there is a noticable differance between tunes. :nod:
Thats the reason I asked. Makes senses doesn't it.
I've been running it for a while now with no problems. the terminals are clean and clear. every setting runs exactly the same: low power, lots of smoke, shifting hard, gets hot real fast. I think it is over fueling to the max. i took it out and the truck is running fine with out any codes or issues. I do not have any mods on my tranny either. has anyone had this issue before? Have your ever seen something like this happening tony? thanks for your quick help by the way man i appreciate it a lot
Too cool for school
so it's always done it?
Discussion Starter #11
No. Problem just started (sorry for not specifying) the chip has run great with no issues at all. All tunes used to work great and have no issues or glitches. No high idle setting (which i wish it had)
I had a problem where I would smoke extremely bad right when I start out with no power and alternating idle while chipped (Different chip) but if i set the chip to stock I was fine. I pulled out the ICP sensor and cleaned off the oil and it cleared up. Prolly not the same thing but worth a shot.
Discussion Starter #13
thank you for your input. i'll give that a try and see if anything clears up. thanks again
Too cool for school
maybe something is happenening to your ICP sensor. The symptoms you dercribe sound associated with the resistor mod. It screws your trans up ans throws the trans out of whack.
pull the plug off of the ICP sensor and see if theres any oil in it. cant hurt anything
Discussion Starter #15
So i pulled the icp and everything is clean. like i said, the truck runs fine with the chip out, so i'm thinking that my chip fried itself or my truck fried it for me. oh well. I don't have the money to buy a new chip so looks like i'll be running N/A for a little while lol. thanks for your help guys
So i pulled the icp and everything is clean. like i said, the truck runs fine with the chip .N/A for a little while lol. thanks for your help guys
Wait a minute!!! You spent money on tunes and you are just going to give up? No I bet ther is somthing with yo truck. Get it on a scanner have them check every thing. OH by the way i had Icp trouble and it did not show up as a code or on a scan I stumbled upon it. Reaplaced good as new.:nod:
If it's a TW chip can't you just send it back to him and have him check it out? He has lifetime reburns on his chips right?
Discussion Starter #18
Does it? i didn't buy it directly from him, i bought it from a person on the site a while back.
If it was an issue with my truck don't you think the symptoms would show up without the chip?
Ok, sounds like the switch may have went bad, pull the chip and switch and send it to me and I will check it out for you, the lifetime reburns only apply to the person who purchases the chip from me or a dealer.
If the chip was fried, then the truck wouldn't run with it on the pcm. Prolly just the switch.
Discussion Starter #20
okay cool. there is no point in wasting your time sending it to you then because i did not purchase it directly from you. but thank you anyways.
1 - 20 of 70 Posts
