1 - 13 of 13 Posts
Hi, I have a 97 F-250 and i just installed a ts chip with the "canned tunes" the truck is basically stock so I figured these would be fine for now, but the question i have is the shifting with the chip, mostly in the 140hp position and 100hp position the way it shifts is hard to explain, first to second shifts smooth but kinda slow and then second to third,and so on, takes quite a while to shift and seems to want die off almost while shifting, not sure if this is how its is supposed to be or if i should just pull the trigger and get the chip reburned with "custom tunes", any help will be appreciated Thanks.
the shifting on the canned tunes leaves ALOT to be desired.
mostly, it's terrible.
only remedy is to send it in to one of the vendors and have
them put a decent set of tunes on it. that will clear up your
shifting issues.
Ok thank you, and is there any damage that could be done to the transmission while running these tunes?
shifting issues.
Ok thank you, and is there any damage that could be done to the transmission while running theses tunes?
Ok thanks, and yes it did have the wrong pcm code the company i order it from told me that the code the chip had was the same programing as my pcm code but as long as the dpc code was the same it was fine but i guess not, so i called again and they charge $40 to just have the correct pcm code burned on so i may do that as the truck is stock for the time being, but I appreciate your offer and i will be interested in getting custom tunes like you offer so i will keep you in mind. Thanks again really appreciate it
Discussion Starter #11
Nope, if they are a legit shop, they should already know to ask for the PCM code off the bat.
Sent from my Pixel XL using Tapatalk
Hey man, i just got off the phone with company and they are claiming that the pcm code i have (NAW6) is the same as the code the chip has burned in (TDE1) and that the shifting issue isnt the chip fault but my transmission fault that it cant hold the additional power. What do you think?
i think they are being lazy. cut your losses and have one of the great guys
on here reburn it for you. it's certainly not the transmissions fault. the
ts trans tunes are shyte. that's all there is too it.
Discussion Starter #13
Yeah they are not trying to help so screw them, And yes I emailed cnc fabrication to see what they recommend for me hopefully they answer soon so I can place an order to have it reburned with custom tunes. Thanks for the input really appreciate it!
1 - 13 of 13 Posts
